Hello All,
When replacing the thermostat in a 1966 HY what is the correct orientation. What is the proper way to install it?
Kind Regards,
Kat & Garric
What is the correct HY thermostat orientation?
- HY Forum Liefhebber
- Kenteken: hy78,hy72
Re: What is the correct HY thermostat orientation?
most people run without one. the flow from the upper hose feeds the radiator. you would orient the switch towards the head. as i said though most simply remove it so there is always flow.
-lelijke Amerikaan
-lelijke Amerikaan
